Generate intelligent isometrics from multiple sources
Piping isometric drawings are among the most important deliverables from plant designs. Bentley OpenPlant Isometrics Manager V8i is the first software to independently create intelligent isometric information from any iRING-compatible 3D model, while working in real time with the same model as the rest of the project team.
Many styles of isometrics can be produced from OpenPlant Isometrics Manager V8i, each with their own set of rules for design status and layout. Isometrics can be produced based on a design state of the components as set in OpenPlant Modeler V8i, such as Issued for Construction. Rules can be defined to control what types of isometric drawings can be created if the components are in a predetermined design state. Time spent checking and reviewing isometrics is now focused on the proper documents where the status is known.
OpenPlant Isometrics Manager V8i is connected to ProjectWise V8i, which provides for the posting of finalized isometrics into the document repository. If a previous version of that isometric exists, it will automatically create a new version, leaving the old version intact for possible future review.
Automatic version control and global distribution: Utilizing ProjectWise as the document store, isometric drawings can be posted directly into the document repository with automatic version control. Team members, regardless of location, can access the most current versions of design documents.
Independent isometrics production: OpenPlant Isometrics Manager V8i is a stand-alone application. Users can generate isometric drawings easily via OpenPlant Isometrics Manager’s simplified interface without the need to use a design application's heavy footprint or more complex interface.
Real-time isometric production from multiple systems: Isometrics can be created from diverse sources, such as OpenPlant Modeler and AutoPLANT. This allows designers the freedom to work in the design application of their choice, while lowering the cost of having to support expensive design seats in order to produce quality isometric drawings.
New User Interface:The OpenPlant Isometrics Manager V8i SELECTseries 5 user interface makes it significantly easier to custom configure isometrics.
Available on Select:
Check Below link:
communities.bentley.com/.../openplant-product-releases---introducing-openplant-support-engineering
Check Videos Content - LEARN Server
Bentley Product Advantage Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
