| Product(s): | Bentley StormCAD, SewerCAD, SewerGEMS, CivilStorm, WaterGEMS, WaterCAD, HAMMER | ||
| Version(s): | 08.11.XX.XX | ||
| Area: | Modeling | ||
| Subarea: | |||
| Original Author: | Mark Pachlhofer, Bentley Technical Support Group | ||
How do I select all elements upstream or downstream of a certain point?
Note: for WaterCAD, WaterGEMS and HAMMER, if multiple sources (reservoirs or tanks) supply flow to the selected element, the path to both will be selected.
