"ustation.exe Entry Point not Found" error when using MicroStation platform
 Product(s):SewerCAD, SewerGEMS, CivilStorm, StormCAD, WaterCAD, WaterGEMS, HAMMER
 Version(s):V8i
 Environment:MicroStation
 Area:Other
When opening the "...for MicroStation" shortcut, the following error appears:
Problem ID#: 72466
Try reinstalling the program and running the integration tool, found in the product Start menu folder, "Integrate ___ with ...." Further troubleshooting steps here:
Troubleshooting MicroStation integration
