| Product(s): | WaterGEMS, HAMMER, WaterCAD | ||
| Area: | Other | ||
| Original Author: | Mark Pachlhofer, Bentley Technical Support Group |
What are the difference between WaterGEMS / WaterCAD and EPANET?
To compare the software we need a way to classify the differences between the software. We will consider the following classification methods in order to compare the two products:
Should the EPANET solver and the WaterGEMS/CAD solver give the same results for a model?
What are the limitations of importing/exporting an EPANET file?
