Product(s): | Bentley PondPack |
Version(s): | CONNECT Edition, V8i |
Area: | Layout and Data Input |
How can I change the SCS unit hydrograph shape factor in Pondpack V8i?
Problem ID#: 42169
First, choose "Triangular" for the "SCS Unit Hydrograph Method" under the "Unit Hydrograph (Advanced)" section of the catchment properties.
Then, enter the shape factor value in the "Shape Factor" field that appears below it.
How do I apply the 'Swamp Factor' when using the SCS Unit Hydrograph or the Tabular TR-55 methods?
How to model travel time, Tt, from TR-55 when using the SCS unit hydrograph method?
