Can StormCAD import an Autodesk (AutoCAD) storm sanitary analysis (SSA) file?
Product(s):StormCAD
Version(s):08.11.06.83
Area:Layout and Data Input
Problem Description
StormCAD cannot directly import an SSA file, however there are ways that you might be able to get the information from the SSA into StormCAD.
Steps to Resolve
Option 1Save the SSA file as a LandXML file, which StormCAD can import
Option 2 -  Export your SSA file elements to shapefiles/CAD files and build your StormCAD model using the modelbuilder tool. You can find directions for how to use modelbuilder here.
What files are necessary to work with the Hydraulics and Hydrology products in the AutoCAD environment?
