Applies To | |||
Product(s): | WaterCAD, WaterGEMS, HAMMER | ||
Version(s): | 08.11.XX.XX | ||
Original Author: | Mark Pachlhofer, Bentley Technical Support Group |
Can I move the labels on a profile for WaterGEMS, WaterCAD, or HAMMER if they overlap?
Yes, the labels can be moved on a profile using the steps below:
1) Click on the drop down arrow next to the Chart Options icon and choose "Chart Options" on the profile. See the screen shot below
2) With the Chart Options manager open click on the Tools tab
3) Click on the "+" button, which opens the Chart Tools Gallery window
4) Choose to add the "Drag Marks" tool by clicking the "Add" button at the bottom of the window
5) Select the labels that you want to drag and move from the "Series" drop down box and click the close button
6) Move the labels on the profile by left clicking on them and dragging them
7) If you want to move a different label go back to the tools tab in the chart options and select that label name in the series drop down
Hydraulics and Hydrology Forum
OpenFlows Product Tech Notes And FAQs
