Product(s): | HAMMER |
Version(s): | 10.02.03.06 |
Area: | Installation |
The CONNECT Edition Update 2.3 release of HAMMER – Build 10.02.03.06 introduces improvements and features to help you be more successful.
Stability enhancements and fixes to reported issues
Compatible Operating Systems
Supported Platforms:
Models saved in this version of HAMMER (10.02.03.06) can also be opened in the initial CONNECT Edition Update 2 versions (10.02.00.XX, 10.02.01.XX and 10.02.02.XX).
Note the following known issue: Computing model saved in version 10.02.03.XX results in "Failed to validate model."
See also: Model backward / forward compatibility
A new Pump Status FlexTable has been included with this release. This will show results at a given time step for the pumps in a model, as well as sparkline that will display how the status changes with time. While transient results are available in the Pump Status FlexTable, the pump status itself will only apply to the initial conditions calculation.
In addition, you can now graph the pump status directly from the Graph manager.
As with all new versions, this release of HAMMER includes fixes to various user-reported issues from the previous release, providing an overall more stable experience.
WaterGEMS and WaterCAD TechNotes and FAQs
Downloading OpenFlows / Hydraulics and Hydrology Software
Cumulative patch set information
Set up notifications for new versions and patch set releases
