| Product(s): | SewerGEMS, SewerCAD | ||
| Version(s): | 10.00.00.40 and later | ||
| Area: | Modeling |
LoadBuilder can be used to assign isolated Property Connection elements to the nearest element by creating a tap and lateral connection. Isolated Property Connections are those that are not connected to any lateral element (they are "orphaned"). Laterals are automatically placed between the source element and the hydraulic network when using LoadBuilder and selecting Property Connection Load Data as the Available LoadBuilder Method. When this method is used, it is assumed that that load data is already available in the Property Connection.
Note:
1. Run the LoadBuilder tool from the Tools tab.
2. Click the New icon
3. Select Property Connection Load Data as the Available LoadBuilder Method and click Next.
4. Optional: Create a selection set containing the links elements (ie. Channel or conduit) that can have taps associated with them.
5. Optional: Create a selection set containing the Property Connection elements that are to be assigned with Loadbuilder.
6. Enter all fields on the Property Connection Nearest Link page and then click Next.
In standalone, when the […] button for Link Layer is clicked, the following dialog displays to select all elements of a particular type or a selection set containing conduits and/or channels.
In ArcMap, when the […] button for Link Layer is selected, the following dialog displays and allows you to select the available Feature Class layer.
Specify the source database field that contains the identifying label data.
In standalone, MicroStation and AutoCAD platforms, this field is always “ElementID”.
In ArcMap, multiple choice are given based on the columns available in the selected FeatureClass Layer.
In standalone, when the […] button for Property Connection Layer is clicked, the following dialog displays to select all Property Connection Elements or available selection sets of Property Connection type.
In ArcMap, when the […] button for Property Connection Layer is selected, the following dialog displays and allows you to select the available Feature Class layer.
If Next is pressed without entering one of these fields, then one of the following errors will display.
If the selected Property Connection Layer doesn't contain any isolated Property Connection elements, then the following message will display.
"There are no results available for the given input parameters. Please verify your data and try again."
7. The Results Preview page contains a list of the nearest elements for each Property Connection. A lateral will be created to connect elements listed in the Property Connection column with the corresponding assigned elements in the Nearest Element column.
Based on the geometric location of a Property Connection, the Nearest Element that it is assigned to could be a link (conduit/channel) or node (catch basin, manhole, transition, cross section or headwall) element type.
8. On the last page of the LoadBuilder wizard, enter a name for the LoadBuilder run and click Finish.
9. Review and close the summary dialog. Close the Loadbuilder Manager.
10. Model Synchronization
After a successful Property Connection nearest link run, one or more lateral and/or tap elements will be created. Therefore, a drawing needs to be synchronized to display them.
Once the Summary Report and Load Manager are closed, the following dialog will display asking if you want to synchronize the drawing:
If you click Yes, a drawing will be synchronized and new elements will be display. Otherwise, the drawing will remain out-of-sync.
An element's active topology state is considered when using LoadBuilder with Property Connection load data. LoadBuilder will not assign a property connection to an inactive element. A Property Connection will only be assigned to a link if both of its nodes are active.
Newly created Lateral and tap elements will have a default values from the active lateral and tap prototypes respectively.
If a tap element is created, it will have a reference link (dashed line) connecting it to the nearest pipe. The dashed line can be turned off by setting the tap property "Show Associated Link Decorations" to False in Element Symbology.
The nearest element the Property Connection is assigned to will vary for different use cases.
If the Property Connection element is perpendicular to the nearest link, and the perpendicular intersection is not within 10ft of a valid node.
If the Property Connection makes a perpendicular intersection with the nearest link within 10 feet of, or beyond the node, but the nearest node is invalid (eg. outfall).
If the Property Connection element is not perpendicular to the nearest link and the nearest node is valid (eg. manhole).
A Property Connection element will be assigned to the nearest node if one of the following are true:
Wiki: Property Connections
Wiki: How to toggle tap node dashed line display
WIki: How do Taps and Laterals work in the storm and sewer products?
Blog [VID]: Introducing individual Property Connections to your model
