| Product(s): | CivilStorm, SewerGEMS, |
| Version(s): | 08.11.03.77 and higher |
| Area: | General |
What is the difference between CivilStorm and SewerGEMS? (CivilStorm vs. SewerGEMS)
Are there things that can only be done in one and not the other?
As of October 2023 and for versions 08.11.03.77 and higher, all of the capabilities of CivilStorm are included with SewerGEMS. SewerGEMS includes the following additional functionality which is not available in CivilStorm:
Model files are compatible between CivilStorm and SewerGEMS. That is, a model saved in CivilStorm can be opened in SewerGEMS and vice-versa, as long as the version you are opening is greater than or equal to the version that the model was saved in.
See the product pages for more:
Differences between solvers: GVF-Convex vs. GVF-Rational vs. Implicit vs. Explicit (SWMM)
