Applies To | |
Product(s): | WaterGEMS, WaterCAD, SewerCAD, StormCAD, CivilStorm, SewerGEMS |
Version(s): | CONNECT Edition, V8i |
Area: | Installation |
Original Author: | Dan Iannicelli, Bentley Technical Support Group |
User cannot populate properties inside the following products for AutoCAD:. WaterGEMS, SewerGEMS, WaterCAD, SewerCAD, StormCAD, or CivilStorm. Please check for the following symptoms.
- If you double-click on any element, it should bring up an AutoCAD command in the command line for that particular window.
- When you double-click and nothing would come up, followed by a blank in display.
To fix this issue, you may have to drag the edge of the drawing over from the left or the right. With user notifications, which are often displayed below the drawing, you may need to drag the bottom of the drawing up. If the manager or dialog is hidden behind the drawing, this will show the manager or dialog. The screenshots below show where you should be able to grab the edge of the drawing to move it:
If other managers are already visible, it is also possible that the properties display is hidden behind another manager. The following video can help with cases like that:
If the above steps don't resolve the issue, you can try resetting the AutoCAD settings to default.
Property grid, Element FlexTable, or other dialog will not open
