Applies To | |
Product(s): | HAMMER |
Version(s): | CONNECT Edition, V8i |
Area: | Calculations |
Original Author: | Scott Kampa, Bentley Technical Support Group |
What does the following user notification mean and how can it be resolved?
"There is an error in the data for this pipe. The associated data is incorrect"
One reason this could occur would be if the flow or headloss in this pipe is very low in the initial conditions. Basically the transient calculation engine is less forgiving in terms of the accuracy of the initial condition values. Even more so with small flows and very small friction head loss. Friction factor calculation with these very small numbers could result in very inaccurate values and the program may not be able to converge on a solution.
First, check to make sure that the initial conditions are well-balanced. If you see "network unbalanced" or "disconnected demand nodes detected", the initial conditions may not be valid, causing pipe headloss/flow and other results that may not be accurate, which then trigger the notification in question if a transient simulation is attempted. The initial conditions need to be reliable before a transient simulation can be attempted. See the following articles for guidance:
Troubleshooting the Network Unbalanced or Cannot solve network hydraulic equations user notification
Disconnected Demand Nodes user notification when computing model
If you are trying to model a pump startup event with a pump that is set to be initially off, you will need some other downstream source to supply any fixed demands, otherwise the results will be invalid and you will likely see the "disconnected demands" notification. In this case, consider starting with the pump initially on, the transient pump type set to "variable speed", then configure the pump transient Operating Rule to gradually turn the pump off, wait for conditions to settle down (which actually may not happen if a vapor or air pocket forms) and then start up. See the section "Disconnected Demand Nodes when calculating initial conditions" near the bottom of this related article: Modeling a Pump Start-Up Transient Event in HAMMER
If the initial conditions are balanced with no other notable notifications, try the following steps to resolve the issue.
Go to Analysis > Calculation Options. Under "Steady State/EPS Solver," double-click the active calculation option to view the properties. In the Properties, make the "Accuracy" value smaller, such as changing the value from 0.001 to 0.00001. Then, compute initial conditions and try computing the transient simulation. A smaller value for the accuracy may allow the flow in the pipe to be closer to zero and thus treated as such by HAMMER, avoiding the pipe friction factor calculation error.
In other cases, the low flow in the pipe may be real (expected), but the friction factor calculation settings may not be set correctly for this situation. First, compare the flow through the pipe to the "Tolerance" transient calculation option. If the pipe flow is greater than the flow tolerance, HAMMER will try to compute the Darcy-Weisbach Friction Factor (f) based on the total headloss across the pipe:
f = hl / [ (L/D)(V^2/2g) ]
Where f = Friction factor, L = pipe length (ft/m), D = pipe diameter (ft/m), V = velocity (ft/s, m/s) g = gravity
In cases where the flow is above the tolerance but resulting in a very small velocity, HAMMER can have difficulty solving the above equation, with certain lengths and diameters. The solution to this is to either increase the Flow Tolerance to be above the flow seen in the pipe in question (which causes it to directly calculate the friction factor based on the roughness factor in the pipe - but this could be problematic if set too high), or set the "Round pipe heads" calculation option to "true" and set the number of decimal places to a number that results in the pipe headloss rounding to zero (in which case it will use a zero for the friction factor). You can making the "accuracy" steady state calculation option smaller (for example 0.0001 instead of 0.001) as a more accurate initial conditions may avoid this situation.
If you experience such low flow pipes, you should consider simplifying the model. Eliminate tees by placing demands at the junction that connects the main line to the tee, a process called skeletonization. This will eliminate the low demands and some of the short pipes. See more here: Preparing a model for analysis in Bentley HAMMER
If you can make adjustments to your model similar to those described above, you will eliminate the user notifications you are getting, plus assure yourself that the proper friction factor is calculated for your model. Looking at the Transient Analysis Output Log will be helpful in eliminating the latter, since this Darcy-Weisbach friction factor is not reported in the properties or flextables. Open the Transient Analysis Output Log from the Report menu. The report will open the Wordpad text editor. You can use CTRL+F to "find", then search for "pipe information" to jump to the section that lists the friction factor per pipe.
What equation does HAMMER use to compute the Darcy-Weisbach friction factor (f)?
