| Product(s): | Bentley WaterGEMS, SewerGEMS, CivilStorm, StormCAD, PondPack, SewerCAD, Hammer, WaterCAD |
| Version(s): | V8i, CONNECT Edition |
| Area: | Licensing |
Do I need to uninstall and reinstall the OpenFlows product and/or upgrade my computer if I upgrade my license feature level? (for example from 1000 pipes to 5000 pipes)
If you are upgrading just the license, then you do not need to uninstall/reinstall the software. Same goes for the computer; if you are just upgrading the license, then you will only need to select the new feature level and restart the product.
If you do not have the latest version installed, then please use the below mentioned link to download the latest or required version of the software and then upgrade to it.
Downloading OpenFlows | Hydraulics and Hydrology Software
