Applies To | |||
Product(s): | Bentley WaterCAD, WaterGEMS,HAMMER, SewerGEMS, SewerCAD, CivilStorm, SewerCAD | ||
Version(s): | 08.11.xx.xx and newer | ||
Environment: | N\A | ||
Area: | Reporting and Results | ||
Subarea: | N\A |
How do you insert a legend into the drawing pane?
Problem ID#: 74079
If the Element Symbology manager isn't already open, go to View > Element Symbology to open it. Highlight the color coding you want to have a legend of and right-click on it. Next, choose Insert Legend and place it on the drawing pane. If you want to change the size of the legend itself, right-click on the legend and choose Scale.
Legend created from color coding is coming in too large
