Locating OpenFlows product error log file
Product(s): WaterGEMS, HAMMER, WaterCAD, SewerGEMS, SewerCAD, StormCAD, CivilStorm, PondPack
Where is the error log file located for the OpenFlows products? (where can one find details about the application and crashes, for troubleshooting purposes?)
The error log files contain a record of all the errors that take place while the application is operating, as well as informational details useful for troubleshooting.
Note: for information on generating log files for installation issues or for SCADAConnect, use the links in the "See Also" section below.
Solution - OpenFlows Water, Storm and Sewer
This section applies to WaterCAD, WaterGEMS, HAMMER, SewerGEMS, SewerCAD, StormCAD and CivilStorm
The location and name depends on the version you're using. Note that you may need to enable viewing of hidden/system files/folders, or you may not be able to navigate to these folders in File Explorer.
10.01.00.72 and greater (including 2023 and 2024)
C:\Users\<Username>\AppData\Local\Bentley\<productname>\<version>\<productname>.csv  (For example WaterGEMS.csv)
10.00.00.XX (initial CONNECT Edition release)
C:\Users\<Username>\AppData\Local\Bentley\<productname>\10\<productname>.log  (For example WaterGEMS.log)
08.XX.XX.XX (V8i and V8 XM)
C:\Users\<Username>\AppData\Local\Bentley\<productname>\8\Haestad.<productname>.log  (For example Haestad.WaterGEMS.log)
In order to send the file to technical support please first compress the log in a zip file. Starting with the CONNECT Edition Update 1 release, you can also go to File > Save to Package, and choose to include the error log file.
Solution - FlowMaster
For FlowMaster 2025 and CONNECT Edition, the FlowMaster.log.csv file can be found in C:\Users\<Username>\AppData\Local\Bentley\FlowMaster\<version>
For FlowMaster V8i, the Haestad.FlowMaster.log file can be found in C:\Users\<Username>\AppData\Local\Bentley\FlowMaster\8
Solution - CulvertMaster
For CulvertMaster 3.X, the log file is called HAESTAD.LOG and is located: C:\Users\<username>\AppData\Roaming\Bentley\CulvertMaster\1
Solution - PondPack
For PondPack CONNECT Edition the log file is called PondPack.log and is found in: C:\Users\<username>\AppData\Local\Bentley\PondPack\10
Increasing Error Log Detail
In some challenging situations, the error log file may not provide adequate information.
By default, the product will store a reasonable amount of debug information in the error log file, such that it does not negatively impact performance or generate too large of a file. If the error log file does not include enough information to troubleshoot the issue in question, the debug level can be increased to generate more information in the log, which could be helpful for troubleshooting.
First, locate the .exe.config file for the product in question. This depends on whether you're using the 32 or 64-bit version of that product. See: installation folder
The file you're looking for begins with the product name and ends with .exe.config. So, using WaterGEMS as an example, the file would be WaterGEMS.exe.config.
Note: if you're using WaterGEMS, SewerGEMS or HAMMER for ArcMap (ArcGIS integrated mode), these changes need to be made to the arcmap.exe.config file, located in the "bin" folder of your ArcMap installation. The default location is: C:\Program Files (x86)\ArcGIS\Desktop10.X\bin
Next, open the config file in a text editor such as Wordpad or Notepad. Add the following highlighted text in the correct location (just before the last line in the file) and save the file. You can copy and paste the text from here.
<?xml version="1.0" encoding="utf-8"?>
<configuration>
<startup useLegacyV2RuntimeActivationPolicy="true">
  <supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.0"/>
</startup>
<runtime>
  <assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
   <probing privatePath="SharedAssemblies" />
   <dependentAssembly>
    <assemblyIdentity name="Bentley.License.Library.NET" publicKeyToken="4bf6c96a266e58d4" />
    <bindingRedirect oldVersion="1.0.0.0" newVersion="9.0.0.39" />
   </dependentAssembly>
  </assemblyBinding>
</runtime>
<system.diagnostics>
  <switches>
   <!-- off=0, Release=1, Debug=2, Debug1=3, Debug2=4 -->
   <add name="TraceLibrary" value="2"/>
  </switches>
</system.diagnostics>
</configuration>
If you are not comfortable with making these changes yourself, you can download a copy here (be sure to log in first or the link will not work). Extract the file corresponding to your product, to the installation folder (see note about 32 vs 64-bit folder above.)
Note: the default trace level is "1". The above example sets it to "2". You can increase to 3 or 4 to provide even more information. However, for performance reasons, you may want to reset this back to "1" when done.
Memory Dump File
In extreme cases if there is inadequate diagnostic information in the standard error log file, technical support may need to obtain a memory dump. This is a file containing the state of your memory when the error occurred. With the error message still open,
1) Run Windows Task Manager (press Ctrl-Shift-Esc or right click in the bar at the bottom of the screen and select "Start Task Manager")
2) In Task Manager, go to the Processes tab and right-click on the crashed process, such as watergems.exe
3) Select Create Dump File
4) Locate the file and compress it into a zip file before sending to technical support.
2D Simulation Error Code Details
When computing a 2D simulation in SewerGEMS or CivilStorm, you may sometimes encounter generic error codes like "ERR100". To find more details on these, look at the StormwaterModel.log file located here:
C:\Users\[USERNAME]\AppData\Local\Temp\Bentley\SewerGEMS\[PROJECT].stsw.$$$_[SCENARIO ID]\General Data\StormwaterModel.log
Note: the scenario ID can be found by looking at the properties of your scenario in the Scenario Manager.
Locate the "ERR" code and look just above it for more details.
"... Stopped Working" error when opening product
Generating a log file for installation problem troubleshooting
How to obtain log information for SCADAConnect
