| Product(s): | WaterGEMS, WaterCAD, SewerCAD, SewerGEMS | ||
| Version(s): | CONNECT Edition, V8i | ||
When trying to bring in loads using LoadBuilder (Projection method > Load Estimation by Population), I keep getting zero loads, although the shapefile contains values.
Problem ID#: 48841
Enter values for the Load Density field (enter your projection). If left at zeros, the loads/demands will be zero.
