| Product(s): | Civil Products (as listed below) |
| Version(s): | 08.11.XX.XX and higher |
| Area: | Modeling |
The purpose of this article is to help you understand the OpenFlows functionality in Drainage and Utilities (previously "Subsurface Utilities"), within Bentley's Civil products. It explains which programs it is available in, and the availability of OpenFlows tools within them.
The OpenFlows functionality that is available in the OpenFlows SewerGEMS, CivilStorm, StormCAD and SewerCAD products was introduced in the V8i SELECTseries 4 (SS4) version (08.11.09.845) of Bentley Civil products. Prior to that Subsurface Utility Engineering (SUE) tools were introduced in SELECTSeries 3 Civil products (version 08.11.09.674+). Since then the CONNECT Edition products have been introduced. These supersede the MX, InRoads, PowerCivil and GEOPAK products.
Here is the list of Civil products for which OpenFlows functionality is available:
Note: this does not apply to these products if they are used in the AutoCAD environment.
OpenFlows functionality within Drainage & Utilities will help users design and analyze all underground utilities, in a single product. Hydraulic model data is stored in a SQLITE file imbedded into the DGN file.
OpenFlows license management within the Civil products.
Note: for a video demonstration, see: Activating Advanced Drainage Capabilities in OpenRoads Designer: Part 1 | Part 2
How to change active OpenFlows license
See also: What if I need more than 100 inlets in StormCAD?
The following features are included in Civil products:
OpenFlows Functionality - how it works in Civil products
With the availability of the Drainage & Utilities tools within your Civil products, you can perform the following things:
A Storm or Storm Sewer file can be updated in standalone and opened in Subsurface Utilities using the steps below:
2) Update and save the file
3) Open the file in one of the Civil products.
4) Go to the Drainage & Utilities workflow > Tools > Synchronize Drawing... the file should update.
Tools in OpenFlows storm-sewer products available within Drainage and Utilities.
Added support for UK Flood Estimation Handbook 2013 Rainfall Data starting with 10.09.00.91 version.
Tools not available from OpenFlows products
Each version of OpenRoads/OpenSite uses a certain version of the underlying OpenFlows technology for drainage. When the need arises to open models between these products and the OpenFlows products (such as SewerGEMS or StormCAD), one needs to consider the corresponding version to ensure compatibility.
See: Platform Compatibility Chart – Civil Products – OpenFlows Products
Learning Resource Guide for new users of Bentley SewerGEMS
Training for drainage functionality in OpenRoads Designer
Drainage and Utilities - Workspace and Standards Development
There is On-demand Answer Hour session video about activating advanced drainage capabilities in civil product. Which includes understanding StormCAD 100 inlets license within civil products, how to utilize 100 inlets license, how to change license to other available license options like StormCAD unlimited, SewerGEMS, CivilStorm, what is meaning and usage of each particular license and which one you should utilize to match your project requirements all this is covered in this answer hour session.
Subsurface Utilities (SUE and StormCAD) Video Clips, TechNotes & FAQs
Performing clash detection of storm/sewer/water models using Bentley Products
OpenRoads Special Interest Group (SIG) FAQs
OpenRoads Designer CONNECT Edition - Wiki Articles and Videos
Answer Hour: Activating Advanced Drainage Capabilities in OpenRoads Designer
