| Product(s): | WaterGEMS, SewerGEMS |
| Version(s): | 08.11.XX.XX and higher | ||
| Area: | Other |
Which versions of WaterGEMS, SewerGEMS and HAMMER support which versions of ArcGIS?
A note on HAMMER: older versions of HAMMER integrated with ArcMap, but ArcMap is no longer supported by Esri so currently only WaterGEMS and SewerGEMS integrate with ArcGIS (ArcGIS Pro).
A note on ArcMap: please see further below regarding ArcMap integration, which is no longer supported as it has been discontinued by Esri.
A matrix of supported versions of ArcGIS Pro for each version of WaterGEMS and SewerGEMS is available here: Platform Compatibility
Generally speaking, the Readme.pdf file (found in the installation folder) for a particular version of WaterGEMS and SewerGEMS shows the range of ArcGIS Pro versions that the software will attempt to integrate. For example if it indicates "version 3.x, minimum 3.1" is supported, it means it will attempt to integrate with version 3.1 and higher, but below 4.x. The compatibility matrix article above indicates the versions that have been fully tested with the respective released version of WaterGEMS and SewerGEMS.
| ArcGIS Pro version | Notes |
| ArcGIS Pro 3.7 | This version is not yet compatible with OpenFlows products as of 26.00.00.5XX. A subsequent release will be made available in the near future to support this version. |
| ArcGIS Pro 3.6 | While version 2024 and earlier will attempt to integrate, official testing/support for 3.6 is introduced in WaterGEMS and SewerGEMS 2026. |
| ArcGIS Pro 3.5 | As of 2025-May-22, this should work with the latest available releases of WaterGEMS and SewerGEMS, but has not been fully tested yet. |
| ArcGIS Pro 3.4 | This is fully supported with WaterGEMS 2024 starting with version number 24.00.02.20 and SewerGEMS 2024 starting with version number 24.00.02.21. |
| ArcGIS Pro 3.3 | This is fully supported starting with WaterGEMS version 24.00.00.26 or greater and SewerGEMS version 24.00.00.25 or greater (these versions contain some important fixes related to 3.3) |
| ArcGIS Pro 3.1+ | Integration with ArcGIS Pro 3.1 and higher (ArcGIS Pro 3.0 and earlier are no longer supported) is available starting with the 2023 release of WaterGEMS and the 2024 release of SewerGEMS. See: How to receive alerts on new version availability Note that ArcGIS Pro 3.X itself requires the Microsoft .NET 6 Windows component as a prerequisite, see this article. Also note that upgrading to 3.2 or later is highly recommended due to the Esri issue mentioned in this article. |
| ArcGIS Pro 2.9 | This version is not supported by version 10.03.04.53 of SewerGEMS and 10.03.05.XX of WaterGEMS. You will need to downgrade to version 2.8 or earlier or upgrade to CONNECT Edition Update 4 (10.04.XX.XX) when available. See: How to receive alerts on new version availability |
| ArcGIS pro 2.7 | please contact Technical Support for a patch for WaterGEMS version 10.03.02.75, or upgrade to a newer version. Without the patch, you may notice problems with element layout, rotate and scale. |
For more information on ArcGIS Pro integration, see: Overview of WaterGEMS for ArcGIS Pro
If the trial version of ArcGIS Pro uses the same installation file as the fully licensed version, the trial period is likely handled by the licensing (Esri/ArcGIS). If this is the case, WaterGEMS should integrate during the trial period, but you will need to ensure that you have a compatible version per the information above.
Esri has ended support for ArcMap, and accordingly, WaterGEMS and SewerGEMS no longer integrate with ArcMap starting with version 2026.
For WaterGEMS and SewerGEMS 2024 and earlier, the version shown in the matrix ("Platform Compatibility" link above) represents the latest compatible "minor" version (minor meaning the "x" in 10.x.y) which we have fully tested (certified). So for example if 10.8 is supported, that means 10.8.# (such as 10.8.1, 10.8.2, etc.) is also supported.
Earlier versions of ArcMap are also supported, in that the OpenFlows product will attempt to integrate with it and if a problem arises, Technical Support will assist. However, it is generally recommended that you use the latest compatible ArcMap version shown in the above article.
