Product(s): | WaterSight |
Version(s): | 10.00. |
Area: | Documentation |
The user has the ability to build additional pages into WaterSight by creating different reports using PowerBI. After PowerBI reports have been created they can be published into WaterSight for the users to consult. You will need to be signed in to a Microsoft account that can access the report. You will be prompted to sign in if you are not already. If you do not have access to the report, you will be prompted to request access from the report owner. For more information about PowerBI licencing, take a look at this article.
To create a PowerBi report you will need to first download the PowerBI connector from the administration. For more information on how to create PowerBI reports and publish them into WaterSight take a look here.
Automatically update of PowerBI reports into WaterSight
WaterSight - Learning Resources Guide
