Platform Compatibility
Product(s): OpenFlows Water (WaterCAD, WaterGEMS, HAMMER)
OpenFlows Sewer (SewerGEMS, SewerCAD)
OpenFlows Storm (CivilStorm, StormCAD, PondPack)
OpenFlows Hydraulic Toolset (FlowMaster, CulvertMaster)
Area: Installation
This article documents platform integration (AutoCAD, MicroStation and ArcGIS) and operating system compatibility for each OpenFlows product version.
A Note on Hardware / System Requirements
For hardware requirements (RAM, CPU, Video card), refer to the Readme.PDF file included in the installation folder of your Bentley OpenFlows product. In general, hardware requirements are highly dependent on the size and complexity of the hydraulic model. The more elements and more complexity in the model and the longer the simulation duration, the more memory it will take up and the more sensitive the performance will be to the speed of the CPU. Since OpenFlows products use a 2D drawing pane, they are generally not graphics intensive. For more information, see How to increase model performance / reduce run time.
To download the latest versions, please see the following article: Downloading OpenFlows / Hydraulics and Hydrology Software.
OpenFlows Water
WaterCAD & WaterGEMS
Version
26.00.00.514 (2026)
24.00.03.22 (2024)
24.00.02.20 (2024)
24.00.01.05 & 24.00.01.12 (2024)
24.00.00.27 (2024)
23.00.00.16 & 23.00.00.19 (2023)
10.04.00.106 & 10.04.00.107 & 10.04.00.108
10.03.05.03 & 10.03.05.05
10.03.04.05
10.03.03.72
10.03.02.75
10.03.01.08
10.03.00.69
10.02.03.06
10.02.02.06
10.02.01.06
10.02.00.43
10.01.01.04
10.01.00.72
10.00.00.55 (CONNECT Ed.)
10.00.00.49 & 10.00.00.50(CONNECT Ed.)
08.11.06.58 (SS6) & 08.11.06.113
08.11.05.61
(SS5)
08.11.04.57
08.11.04.58
(SS4)
08.11.04.50
(SS4)
08.11.03.16
08.11.03.17
08.11.03.19
(SS3)
08.11.02.31
(SS2)
08.11.01.32
(SS1)
Date Released 2026-May-19 2025-Sep-2 2025-Jan-23 2024-Jul-01 / 2024-Aug-08 2024-May-7 / 2024-May-24 2023-Sep-27 / 2023-Nov-24 2022-Sep-8 / 2022-Sep-15 / 2022-Sep-26 2021-Sep-7 2021-Jul-1 2021-Apr-6 2020-Nov-12 2020-May-28 2020-Mar-11 2019-Dec-2 2019-Sept-20 2019-May-2 2018-Dec-28 2018-May-9 2017-Dec-22 2017-June-16 2016-Oct-12 / 2016-Nov-28 2015-Aug-27 / 2016-Feb-10 2014-Aug-4 2013-Jul-1 2013-May-6 2011-Jul-8 2010-Nov-24 2009-Oct-26
O/S compatibility
Windows 11, 10, Server 2019/2022
Windows 10, 8.X, Server 2012
Windows 10, 8, Server 2008/2012
Windows 10, 8,  7, Server 2008/2012
Windows 10, 8, 8.1, 7 SP1 (32 & 64-bit for all)
Windows 7, SP1
Vista SP2,
8, 8.1(32/64 bit), Windows 10
Windows 8.X, 7, Vista
Note: XP no longer supported.
Windows 7, 8, Vista, XP, 2008, Server 2003
Windows XP, 7, Server 2003, Vista, Server 2008 Windows XP, 7, Server 2003, Vista, Server 2008 Windows XP, 7, Server 2003, Vista, Server 2008 Windows XP, 7, Server 2003, Vista, Server 2008
Supported AutoCAD Versions.
(Alternatives here.)
2025, 2026 (64-bit) 2024, 2025, 2026 (64-bit) 2024, 2025 (64-bit) 2023, 2024 (64-bit) 2023, 2024 (64-bit) 2023, 2024 (64-bit) 2022, 2023, 2024*
(64-bit)
*contact Support
2019 (32/64-bit), 2020, 2021, 2022 (64-bit) 2019 (32/64-bit), 2020, 2021, 2022 2019 (32/64-bit), 2020, 2021 (64-bit) 2019 (32/64-bit), 2020, 2021 (64-bit) 2019 (32/64-bit), 2020, 2021 (64-bit) 2018, 2019 (32/64-bit), 2020 (64-bit) 2018, 2019 (32/64-bit), 2020 (64-bit) 2018, 2019 (32/64-bit), 2020 (64-bit) 2018, 2019 (32/64-bit), 2020 (64-bit) 2018, 2019 (32/64-bit) 2017, 2018, 2019 (32/64-bit) 2018, (32/64-bit), 2017(32/64-bit), 2018 (32/64-bit),
2017(32/64-bit), 2016 (32/64-bit)
2017(32/64-bit), 2016 (32/64-bit) 2016 (32/64-bit)2015 (32/64-bit) 2015 (32/64 bit)
2014 (32/64 bit)
2014 (32/64 bit)
2013 (32/64 bit)
2012 (32/64 bit)
2013 (32/64 bit)
2012 (32/64 bit)
2012 (32/64 bit)
2011 (32 bit)
2011 (64 bit)*
2011 2010* 2010 2009*
Certified MicroStation versions.
2023, 2024, 2025, 2026
(see this for 2024)
2023, 2024, 2025
(see this for 2024)
2023, 2024
(see this for 2024)
2023, CONNECT Edition
(see this for 2024)
CONNECT Edition
V8i SS10, CONNECT Edition
V8i SS10
V8i SS10
V8i SS10
V8i SS10
V8i SS4
V8i SS4
V8i SS4
V8i SS4
V8i SS4
V8i SS4
V8i SS4
8.11.7.x and 8.11.9.x
8.11.7.X & 8.11.9.X
08.11.09.459(SS4) 08.11.09.357 (SS3)
08.11.07.443 (SS2)
08.11.09.xx (SS3)
08.11.07.xx (SS2)
8.11.7.443 (SS2)
08.11.09.xx (SS3)
8.11.7.443 (SS2) 8.11.7.x
Supported ArcGIS Pro and ArcMap versions (WaterGEMS)
ArcGIS Pro 3.x (min 3.1, max 3.6)
Details here
ArcGIS Pro (min 3.1, tested up to 3.5)
ArcMap 10.8.X
Details here
ArcMap 10.8.X
Details here
ArcGIS Pro 3.1+
ArcMap 10.8.X
Details here
ArcGIS Pro 3.1+
ArcMap 10.8.X
Details here
ArcGIS Pro 3.1+
ArcMap 10.8.X (Details here)
ArcGIS Pro 2.8.0.29751 through 2.9.X (details here)
ArcGIS Pro 2.6-2.8 (see details here),
ArcGIS Pro 2.6&2.7 (see details here),
ArcGIS Pro 2.6 (see details here),
ArcMap 10.8.X (see details here) ArcMap 10.8.X (see details here) ArcMap 10.7.1 (see details here) ArcMap 10.7.1 (see details here) ArcMap 10.7 (see details here) ArcMap 10.6.1 (see details here) ArcMap 10.6.1 (see details here) ArcMap 10.5.X (see details here) ArcMap 10.5.X (see details here) ArcMap 10.4.1 (see details here) ArcMap 10.3.x (see details here) ArcMap 10.3.X (via patch) (see details here) ArcMap 10.2 (see details here)
ArcMap 10.1 SP1 (see details here) ArcMap 10.0 (see details here) ArcMap 10.0 (see details here) ArcMap 9.3 SP1 (see details here)
Supported ProjectWise versions
2025, 2024, 2023,  CONNECT Ed.
2023, 2024, CONNECT Ed.
2023, CONNECT Ed., V8i SS3/SS4
CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 V8i SS3/SS4 V8i SS3/SS4 V8i SS3/SS4 V8i SS3/SS4 V8i SS3/SS4 V8i SS3/SS4 V8i, V8 XM V8i, V8 XM V8i, V8 XM V8i, V8 XM V8i, V8 XM
Licensing Method Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service SELECTserver SELECTserver SELECTserver SELECTserver SELECTserver SELECTserver SELECTserver SELECTserver SELECTserver SELECTserver SELECTserver
Version of .NET needed 4.8 4.8 4.8 4.8 4.8 4.7.2 (build 16) or 4.8 (build 19) 4.7.2 4.7.2 4.7.2 4.7.2 4.6.2 4.6.2 4.6.2 4.6.1 4.6.1 4.6.1 4.6.1 4.6.1 4.6.1 4.6.1 4.5.1 3.5 SP1 (08.11.06.58), 4.5.1 (08.11.06.113) 3.5 SP1 3.5 SP1 3.5 SP1 3.5 SP1 3.5 SP1 3.5 + SP1
HAMMER
Version
26.00.00.514 (2026)
24.00.03.22 (2024)
24.00.02.20 (2024)
24.00.00.27 (2024)
10.03.04.05
10.03.03.72
10.03.02.75
10.03.01.08
10.03.00.69
10.02.03.06
10.02.02.06
10.02.01.06 10.02.00.43 10.01.01.04 10.01.00.72 10.00.00.55 (CONNECT Ed.) 10.00.00.49 (CONNECT Ed.)
08.11.05.61
(SS5)
08.11.04.57
08.11.04.58 (SS4)
08.11.04.50 (SS4)
08.11.03.16
08.11.03.17
08.11.03.19
(SS3)
08.11.02.31 (SS2) 08.11.01.32
(SS1)
Date Released 2026-May-19 2025-Sep-2 2025-Jan-23 2024-Jul-01 / 2024-Aug-08 2024-May-7 / 2024-May-24 2023-Sep-27 / 2023-Nov-24 2022-Sep-8 / 2022-Sep-15 2021-Sep-7 2021-Jul-1 2021-Apr-6 2020-Nov-12 2020-May-28 2020-Mar-11 2019-Dec-2 2019-Sept-20 2019-May-2 2018-Dec-28 2018-May-9 2017-Dec-22 2017-June-16 2016-Oct-12 2015-Aug-27 2014-Aug-4 2013-Jul-1 / 2013-Nov-5 2013-May-6 2011-Jul-8 2010-Dec-7 2009-Oct-26
O/S compatibility Windows 11, 10, Server 2019/2022 Windows 11, 10, Server 2019/2022 Windows 11, 10, Server 2019/2022 Windows 11, Windows 10, Server 2019/2022 Windows 11, Windows 10, Server 2019/2022 Windows 11, Windows 10, Server 2019/2022 Windows 11, Windows 10, Server 2019/2022 Windows 10, Windows 8.X, Server 2012 Windows 10, Windows 8.X, Server 2012 Windows 10, Windows 8.X, Server 2012 Windows 10, Windows 8, Server 2008/2012 Windows 10, Windows 8,  Windows 7, Server 2008/2012 Windows 10, Windows 8,  Windows 7, Server 2008/2012 Windows 10, Windows 8, Windows 7,Server 2008/2012 Windows 10, Windows 8,  Windows 7, Server 2008/2012 Windows 10, Windows 8, Windows 7, Server 2008/2012 Windows 10, Windows 8, Windows 7, Server 2008/2012 Windows 10, Windows 8,  Windows 7, Server 2008/2012 Windows 10, Windows 8,  Windows 7, Server 2008/2012 Windows 10, Windows 8, Windows 7 (32 & 64-bit for all) Windows 10, Windows 8, Windows 7 (32 & 64-bit for all)
Windows 7,
Vista SP2,
Windows 8, 8.1(32/64 bit), Windows 10
Windows 7, 8, Server 2003, Vista, Server 2008
Note: XP no longer supp.
Windows XP, 7, 8, Server 2003, Vista, Server 2008
2025, 2026 (64-bit)
2024, 2025 (64-bit)
2023, 2024 (64-bit)
2023, 2024 (64-bit)
2023, 2024 (64-bit)
2022, 2023
(64-bit)
2019, 2020, 2021, 2022 (32/64-bit)
2019, 2020, 2021 (32/64-bit)
2018, 2019, 2020 (32/64-bit)
2018 (32/64-bit),
2017 (32/64-bit), 2016 (32/64-bit)
2016 (32/64-bit)
2015 (32/64-bit)
2015 (32/64 bit)
2014 (32/64 bit)
2012, 2013, 2014 (32/64 bit)
2013 (32/64 bit)
2012 (32/64 bit)
2012 (32/64 bit)2011 (32/64 bit) 2011, 2010
(only basic testing for 2010)
2010, 2009
(only basic testing for 2009)
Supported ArcMap versions N/A N/A (can be enabled) N/A (can be enabled) N/A (can be enabled)  N/A (can be enabled) ArcMap 10.8.X (see details here) ArcMap 10.8.X (see details here) ArcMap 10.8.X (see details here) ArcMap 10.8.X (see details here) ArcMap 10.8.X (see details here) ArcMap 10.8.X (see details here) ArcMap 10.8.X (see details here) ArcMap 10.8.X (see details here) ArcMap 10.7.1 (see details here) ArcMap 10.7.1 (see details here) ArcMap 10.7 (see details here) ArcMap 10.6.1 (see details here) ArcMap 10.6.1 (see details here) ArcMap 10.5 (see details here) ArcMap 10.5 (see details here) ArcMap 10.4.1 (see details here) ArcMap 10.3.X (see details here) ArcMap 10.2.1 (10.3.X in patch) (see details here) ArcMap 10.2 (build .58 only)10.1 (see details here)
ArcMap 10.1 (see details here)
ArcMap 10.0 (see details here) ArcMap 10.0 (see details here) ArcMap 9.3.1 (see details here)
(see this for 2024)
2023, 2024, 2025
(see this for 2024)
2023, 2024
(see this for 2024)
(see this for 2024)
2023, CONNECT Edition 2023, CONNECT Edition CONNECT Edition V8i SS10, CONNECT Edition V8i SS10 V8i SS10 V8i SS10 V8i SS10 V8i SS4 V8i SS4 V8i SS4 V8i SS4 V8i SS4 V8i SS4 V8i SS4 8.11.7.x and 8.11.9.x 8.11.7.x and 8.11.9.x
8.11.7.X & 8.11.9.X
08.11.09.459
(SS4)
08.11.09.357 (SS3)
08.11.07.443 (SS2)
08.11.09.357 (SS3)
08.11.07.443(SS2)
08.11.07.443 08.11.07.443 8.11.7.x
Supported ProjectWise versions 2025, 2024, 2023,  CONNECT Ed. 2023, 2024, CONNECT Ed. 2023, 2024, CONNECT Ed. 2023, CONNECT Ed., V8i SS3/SS4 2023, CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 V8i SS3/SS4 V8i SS3/SS4 V8i SS3/SS4 V8i SS3/SS4
V8i SS3/SS4
V8i SS3/SS4
V8i SS3/SS4
V8i SS3/SS4
Version of .NET needed 4.8 4.8 4.8 4.8 4.8 4.7.2 (build 16) or 4.8 (build 19) 4.7.2 4.7.2 4.7.2 4.7.2 4.6.2 4.6.2 4.6.2 4.6.1 4.6.1 4.6.1 4.6.1 4.6.1 4.6.1 4.6.1 4.5.1 3.5 SP1 (06.58), 4.5.1 (06.113) 3.5 SP1 3.5 SP1 3.5 SP1 3.5 SP1 3.5 SP1 3.5 SP1
OpenFlows Sewer
SewerCAD
Version
26.00.00.514 (2026)
24.00.03.23 / 24.00.03.27
24.00.02.21 (2024)
24.00.00.26 (2024)
10.04.00.158
10.03.04.53
10.03.03.44
10.03.02.04
10.03.01.08
10.03.00.76/77
10.02.03.03
10.02.02.04
10.02.01.04 10.02.00.55 10.01.01.04 10.01.00.70 10.00.00.45 (CONNECT Ed.) 10.00.00.40 (CONNECT Edition) 08.11.05.113 (SS5 with CC) 08.11.05.58(SS5) 08.11.04.54
(SS4)
08.11.03.84
08.11.03.83
(SS3)
08.11.03.77
(SS3)
08.11.02.75
(SS2)
08.11.02.49
(SS2)
08.11.02.46
(SS2)
Date Released 2026-May-19 2025-Sep-4 / 2025-Oct-3 2025-Jan-23 2024-Jul-01 / 2024-Aug-08 2024-May-7 / 2024-May-24 2023-Mar-2 2021-Jul-1 2021-Feb-22 2020-Dec-1 2020-May-28 2020-Mar-11 2019-Dec-2 2019-Sept-20 2019-May-2 2018-Dec-28 2018-May-9 2017-Nov-17 2017-June-16 8/18/2016 2/10/2016 05/08/2015 07/15/2013 07/15/2013 01/17/2013 11/07/2011 12/16/2010 07/01/2010
O/S compatibility
Windows 11,
Windows 10, Server 2019 and 2022
Windows 11,
Windows 11,
Windows 11,
Windows 7, 8, 10, Server 2008
See alternatives here.
2025, 2026 (64-bit)
2024, 2025 (64-bit)
2023, 2024 (64-bit)
2023, 2024    (64-bit)
2022, 2023, 2024*
(32/64-bit)
*contact Support
2018 (32/64-bit),
2016 (32/64-bit)
2015 (32/64-bit)
2014, 2015, 2016
(32/64 bit)
2015
(32/64 bit), 2014
(32/64 bit)
2012, 2013, 2014
(32/64 bit)
2013
(32/64 bit), 2012
(32/64 bit)
2012
(32/64 bit)2011
(32/64 bit)
2011, 2010 2011, 2010
Alternatives here.
(see this for 2024)
2023, 2024, 2025
(see this for 2024)
2023, 2024
(see this for 2024)
(see this for 2024)
2023, CONNECT Edition CONNECT Edition V8i SS10, CONNECT Edition V8i SS10 V8i SS10 V8i SS10 V8i SS4 V8i SS4 V8i SS4 V8i SS4 V8i SS4 V8i SS4 V8i SS4 V8i SS4 V8i SS4 V8i SS3 V8i SS3 08.11.09.357(V8i SS3) 08.11.09.357
(SS3)08.11.07.443
(V8i SS2)
08.11.09.357(SS2), 08.11.07.443 (V8i SS3) 08.11.07.443
(SS2)
08.11.09.357
(V8i SS3)
8.11.7.x 8.11.7.x
Supported ProjectWise versions 2025, 2024, 2023,  CONNECT Ed. 2023, 2024, CONNECT Ed. 2023, 2024, CONNECT Ed. 2023, CONNECT Ed., V8i SS3/SS4 2023, CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 CONNECT Ed., V8i SS3/SS4 V8i SS3/SS4 V8i SS3/SS4 V8i SS3/SS4 V8i SS3/SS4 V8i SS3/SS4 V8i SS3/SS4 V8i SS3/SS4 V8i SS3/SS4 V8i SS3/SS4 V8i, V8 XM V8i, V8 XM V8i, V8 XM
Licensing Method Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service SELECTserver SELECTserver SELECTserver SELECTserver SELECTserver SELECTserver SELECTserver SELECTserver SELECTserver SELECTserver SELECTserver SELECTserver
Version of .NET needed 4.8 4.8 4.8 4.8 4.8 4.7.2 4.7.2 4.6.2 4.6.2 4.6.2 4.6.2 4.6.1 4.6.1 4.6.1 4.6.1 4.6.1 4.6.1 4.6.1 4.5.1 4.5.1 3.5 3.5 SP1 3.5 SP1 3.5 SP1 3.5 SP1 3.5 SP1 3.5 SP1
SewerGEMS
Version
26.00.00.514 (2026)
24.00.03.23 & 24.00.03.27
24.00.02.21 (2024)
24.00.00.26 (2024)
10.04.00.158
10.03.04.53
10.03.03.44
10.03.02.04
10.03.01.08
10.03.00.76/77/78
10.02.03.03
10.02.02.04
(SS5)
08.11.04.54(SS4) 08.11.03.83/84
(SS3)
08.11.03.77
(SS3)
08.11.02.75
(SS2)
08.11.02.49(SS2)
Date Released 2026-May-19 2025-Sep-4 / 2024-Oct-3 2025-Jan-23 2024-Jul-01 / 2024-Aug-08 2024-May-7 / 2024-May-24 2023-Mar-2 2021-Jul-1 2021-Feb-22 2020-Dec-1 2020-May-28 2020-Mar-11 2019-Dec-2 2019-Sept-20 2019-May-2 2018-Dec-28 2018-May-9 2017-Nov-17 2017-June-16 8/18/2016 2/10/2016 05/08/2015 06/03/2014 07/15/2013 12/19/2012 11/07/2011 12/16/2010
O/S compatibility
Windows 11,
Windows 11,
Windows 11,
Windows 11,
Windows 10, Windows 8,  Windows 7, Server 2008/ 2012
Windows 7, 8, 10, Vista, Server 2008, Server 2012
Windows 7, 8, Vista, Server 2008
Windows XP, 7, 8, Server 2003, Vista, Server 2008 Windows XP, 7, 8, Server 2003, Vista, Server 2008 Windows XP, 7, Server 2003, Vista, Server 2008 Windows XP, 7, Server 2003, Vista, Server 2008
2025, 2026 (64-bit)
2024, 2025 (64-bit)
2023, 2024 (64-bit)
2023, 2024 (64-bit)
2022, 2023, 2024*
(32/64-bit)
*contact Support
2018 (32/64-bit),
2017 (32/64-bit, 2016 (32/64-bit)
2016 (32/64-bit), 2015 (32/64-bit)
2014, 2015, 2016
(32/64 bit)
2014, 2015
(32/64 bit)
2011, 2012, 2013, 2014 (32/64 bit)
2013 (32/64 bit)2012 (32/64 bit)2011 (32 bit) 2012
(32/64 bit), 2011 (32 bit), 2011 (64 bit)
2011, 2010
ArcGIS Pro (min 3.1, max 3.6)
Details here
ArcMap 10.8.X
Details here
ArcMap 10.8.X
Details here
ArcGIS Pro 3.1+
ArcMap 10.8.X
see details here
ArcGIS Pro 3.1+
ArcMap 10.8.X
see details here
ArcGIS Pro 2.8.0.29751-2.9.X (see details here),
ArcGIS Pro 2.6.X-2.8.X (see details here),
ArcMap 10.8.X (see details here) ArcMap 10.8.X (see details here) ArcMap 10.8.X (see details here) ArcMap 10.7.1 (see details here) ArcMap 10.7.1 (see details here) ArcMap 10.7 (see details here) ArcMap 10.6.1 (see details here) ArcMap 10.6.1 (see details here) ArcMap 10.5 (see details here) ArcMap 10.5 (see details here) ArcMap 10.4.1 (see details here) ArcMap 10.3 (see details here) ArcMap 10.3 (see details here) ArcMap 10.2 SP1 (see details here) ArcMap 10.2 (see details here) ArcMap 10.1 (see details here)
ArcMap 9.3.x (see details here)
(see this for 2024)
2023, 2024, 2025
(see this for 2024)
2023, 2024
(see this for 2024)
(see this for 2024)
(SS3)
08.11.09.357 (SS3) 08.11.09.357 (SS3)8.11.7.443 (SS2) 08.11.7.x08.11.09.209
(beta)
08.11.7.x
OpenFlows Storm
StormCAD
Version
26.00.00.514 (2026)
24.00.03.23 (2024)
24.00.02.21 (2024)
24.00.00.26 (2024)
10.04.00.158
10.03.04.53
10.03.03.44
10.03.02.04
10.03.01.08
10.03.00.76/77
10.02.03.03
10.02.02.04
(SS4)
08.11.03.83/84(SS3)
08.11.03.77(SS3)
08.11.02.75(SS2)
08.11.02.38(SS2)
Date Released 2026-May-19 2025-Sep-4 2025-Jan-23 2024-Jul-01 / 2024-Aug-08 2024-May-7 / 2024-May-24 2023-Mar-2 2021-Jul-1 2021-Feb-22 2020-Dec-1 2020-May-28 2020-Mar-11 2019-Dec-2 2019-Sept-20 2019-May-2 2018-Dec-28 2018-May-9 2017-Nov-17 2017-June-16 8/18/2016 2/10/2016 5/8/2015 6/3/2014 7/15/2013 1/7/2013
11/7/2011
12/16/2010
O/S compatibility
Windows 11,
Windows 11,
Windows 11,
Windows 11,
Windows 10, 8, Server 2008/R2, Server 2012
Windows 10,8, 7, Server 2008, Server 2012
Windows 10*, 8, 7, Server 2008, Server 2012
Windows 7, 8, 8.1, Vista, Server 2008
Windows XP, 7, 9=8, Server 2003, Vista, Server 2008
2025, 2026 (64-bit)
2024, 2025 (64-bit)
2023, 2024 (64-bit)
2023, 2024 (64-bit)
2022, 2023, 2024*
(32/64-bit)
*contact Support
2016 (32/64-bit)
2016 (32/64-bit)
2015 (32/64-bit)
2014, 2015, 2016
(32/64 bit)
2015
(32/64 bit)
2014
(32/64 bit)
2013 (32/64 bit)
2012 (32/64 bit)
2013
(32/64 bit)
2012
(32/64 bit)
2012
(32/64 bit)2011
(32/64 bit)
2011, 2010, 2009
(see this for 2024)
2023, 2024, 2025
(see this for 2024)
2023, 2024
(see this for 2024)
(see this for 2024)
CONNECT Edition
V8i SS10
V8i SS10
V8i SS10
V8i SS4
V8i SS4
V8i SS4
V8i SS4
V8i SS4
V8i SS4
V8i SS4
V8i SS4
V8i SS4
V8i SS3
V8i SS3
08.11.09.357 (SS3)
08.11.7.443 (SS2)
08.11.09.357 (SS3)
08.11.7.443 (SS2)8.11.09.357 (SS3) 8.11.7.443 (SS2)8.11.9.209 (beta)
8.11.5, 8.11.7
V8i SS3/SS4
V8i SS3/SS4
V8i SS3/SS4
V8i SS3/SS4
V8i SS3/SS4
V8i SS3/SS4
V8i SS3/SS4
V8i SS3/SS4
V8i, V8 XM
Licensing Method
SELECTserver
SELECTserver
SELECTserver
SELECTserver
SELECTserver
SELECTserver
SELECTserver
SELECTserver
SELECTserver
4.6.1
4.5.1
4.5.1
3.5
3.5 SP1
3.5 SP1
3.5 SP1
3.5 SP1
3.5 SP1
CivilStorm
Version
26.00.00.514 (2026)
24.00.03.23 (2024)
24.00.02.21 (2024)
24.00.00.26 (2024)
10.04.00.158
10.03.04.53
10.03.03.44
10.03.02.04
10.03.01.08
10.03.00.76/77
10.02.03.03
10.02.02.04
10.02.01.04 10.02.00.55 10.01.01.04 10.01.00.70 10.00.00.45 10.00.00.40 (CONNECT Edition) 08.11.05.113 (SS5 with CC) 08.11.05.58
(SS5)
08.11.04.54
(SS4)
08.11.03.83/84
(SS3)
08.11.03.77
(SS3)
08.11.02.75 (SS2) 08.11.02.65 (SS2)
Date Released 2026-May-19 2025-Sep-4 2025-Jan-23 2024-Jul-01 / 2024-Aug-08 2024-May-7 / 2024-May-24 2023-Mar-2 2021-Jul-1 2021-Feb-22 2020-Dec-1 2020-May-28 2020-Mar-11 2019-Dec-2 2019-Sept-20 2019-May-2 2018-Dec-28 2018-May-9 2017-Nov-17 2017-June-16 8/18/2016 2/10/2016 05/08/2015 6/03/2014 7/15/2013 1/17/2013 11/07/2011 12/16/2010
O/S compatibility
Windows 11,
Windows 11,
Windows 11,
Windows 11,
2025, 2026 (64-bit)
2024, 2025 (64-bit)
2023, 2024 (64-bit)
2023, 2024 (64-bit)
2022, 2023, 2024*
(32/64-bit)
*contact Support
2018 (32/64-bit),
2016 (32/64-bit)
2015 (32/64-bit)
2014, 2015, 2016
(32/64 bit
2015 (32/64 bit)
2014 (32/64 bit)
2013 (32/64 bit), 2012 (32/64 bit), 2011 (32 bit)
2012
(32/64 bit), 2011
(32/64 bit)
2011, 2010
(see this for 2024)
2023, 2024, 2025
(see this for 2024)
2023, 2024
(see this for 2024)
(see this for 2024)
(SS3)
08.11.09.357 (SS3)08.11.07.443
(SS2)
08.11.09.357(SS3)08.11.07.443 (SS2)
8.11.7.X
8.11.9.209 (beta)
8.11.7.X
V8i, V8 XM
V8i, V8 XM
PondPack
Version
10.02.00.01
10.00.00.02
08.11.01.56
08.11.01.54
08.11.01.51
10.01.04.00
Date Released
2019-Jan-3
2018-Aug-8
2012-Mar-8
2010-Dec-16
2009-Oct-26
2008-Nov-7
O/S compatibility
Windows 11, 10,  8/8.1, 7 SP1 (32 & 64-bit for all),
Windows 10, 8/8.1, 7 SP1 (32 & 64-bit for all), Server 2008/R2, Server 2012
Windows XP, 7, Server 2003, Server 2008, Vista,
Windows 8, 8.1
Windows 10
Windows XP, Server 2003, Server 2008, Vista Windows XP, Server 2003, Vista
(* = basic testing only)
2012 (32 bit)
2011 (32 bit)*
2012 (32 bit)
2011 (32 bit)*
2012 (32 bit)
2011 (32 bit)*
2011
2010
2010
2009*
N/A
8.5.xx.xx /8.11.7.xx
8.11.5.x
N/A
V8i SS3/SS4
V8i SS3/SS4
V8i SS3/SS4
V8i SS3/SS4
V8i, V8 XM
SELECTserver
SELECTserver
3.5 SP1
3.5 SP1
3.5 SP1
3.5 SP1 3.5 SP1 1.1
FlowMaster
Version 25.00.00.982 10.03.00.03 10.02.00.01 10.00.00.02 08.11.01.03 08.11.00.03 08.01.071.00 08.01.068
Date Released 2025-Oct-10 2020-Mar-23 2019-Jan-3 2018-Sep-6 2009-Nov-14 2008-Aug-27 2007-Mar-6 2006-Nov-10
O/S compatibility
Windows 8, 8.1
Windows 10
Windows XP, Server 2003, Server 2008, Vista,
Windows 2000, 2003, XP, Vista
Windows 2000, XP
24.x, 23.x, 10.x, V8i SS3/SS4
V8i, V8 XM
V8i, V8 XM
V8i, V8 XM
V8 XM
V8 XM
Licensing Method Subscription Entitlement Service Subscription Entitlement Service Subscription Entitlement Service SELECTserver SELECTserver SELECTserver SELECTserver SELECTserver / Legacy
Version of .NET needed 4.8 3.5 SP1 & 4.6.2 3.5 SP1 & 4.6.2 3.5 SP1 & 4.6.2 2.0 2.0 1.1 1.1
CulvertMaster
Version 10.03.00.03 03.03.00.04 (V8i Generation - see note on Support Policy) 03.02.00.01 03.01.010.00 03.01.009.00
Date Released 2020-Mar-19 2009-Nov-5 2008-Aug-11 2007-Feb-14 2005-Dec-6
O/S compatibility
Windows Vista SP2*, XP SP3
(32/64 bit)*, XP SP2 or later
(32/64 bit), Server 2003 SP2 or later, 2008 Server, Windows 7, Windows 2008 Server R2
Windows 8, 8.1
Windows 10
Windows Server 2003 SP1 or later, Server 2003 (64 bit), Windows XP SP2 or later*, Windows XP (64 bit), Windows Vista*, Windows Vista
(64 bit)
Windows 2000*, Windows Server 2003, *Windows XP
(32/64 bit)*, Windows Vista
(32 bit/64 bit)*
Windows 2000*Windows XP
(32/64 bit)*
Licensing Method Subscription Entitlement Service SELECTserver SELECTserver SELECTserver / Legacy SELECTserver / Legacy
Supported ProjectWise versions CONNECT Ed., V8i SS3/SS4 V8i, V8 XM V8i, V8 XM V8 XM V8 XM
3.5 SP1 & 4.6.2
see also)
2.0 2.0 2.0 1.1
FLOOD
Version 10.03.00.01
Date Released 2020-Mar-03
O/S compatibility Windows 11, Windows 10, Windows 8/8.1, Windows 7, Windows Server 2012+
OpenFlows Functionality in OpenRoads Designer / OpenSite Designer / OpenRail Designer
Each version of OpenRoads Designer, OpenSite Designer, and OpenRail Designer uses a different version of the OpenFlows technology (SewerGEMS/StormCAD). For model compatibility, see the table near the bottom of the following article: Understanding OpenFlows Hydraulics and Hydrology Functionality in Civil Products
If you own this license It will include these Storm-Sewer functions: Subsurface Utility Engineering functionality
  • Any V8i Civil product which does not include GEOPAK Drainage, InRoads S&S or MX Drainage
  • None
  • None
  • Any V8i Civil product which includes GEOPAK Drainage, InRoads Storm and Sanitary, or MX Drainage
  • Storm water peak flow design and analysis
  • Max 100 Inlets in any single drainage model
  • Storm/Sanitary attributes
  • Utilities can be modeled in 3D
  • No SUE attributes
  • No Utility Conflict Tools
  • Any of the above plus either:
  • StormCAD Unlimited
  • SewerCAD
  • CivilStorm
  • SewerGEMS
  • Unlocks additional hydraulics calculation capabilities, according to which license is activated.
  • No SUE attributes
  • Any of above plus a Subsurface Utility Engineering license
  • Same hydraulic capabilities as above according to which hydraulics license is active.
  • Unlocks SUE attributes
  • Unlocks Utility Conflict Tools
  • Any CONNECT Edition Civil product
  • SUE attributes
  • Utility Conflict Tools
  • Any CONNECT Edition Civil product plus either:
    • SewerCAD
    • CivilStorm
    • SewerGEMS
  • SUE attributes
NOTE: If you have SELECT OpenAccess licensing, you will have all the features above available for use.
MicroStation, AutoCAD and ArcGIS integration
Please note that the Standalone platform is always available and integration with a platform like AutoCAD, MicroStation or ArcGIS is not required. See : CAD Functionality in Standalone as an Alternative to AutoCAD or MicroStation Integration For example you can import MicroStation CAD files into the Standalone version using ModelBuilder and export the model plan view from Standalone to DXF format and insert that into your MicroStation design file.
AutoCAD LT (Lite)
Bentley's OpenFlows applications only integrate with full versions of AutoCAD and will not integrate with AutoCAD LT (Lite).
ProjectWise Edition Integration
Note that versions of the OpenFlows products that are listed as being able to integrate up to ProjectWise CONNECT Edition will not integrate with ProjectWise 2023, 2024, etc.
ArcGIS Pro Integration
ArcGIS Pro integration support started with WaterGEMS version 10.03.02.75
See: ArcGIS Pro Integration
