All of the graphic and text columns that can be included in logs can also appear on fence report fence posts.
Fence report design in gINT is very flexible, enabling the display of all of the graphic and text entities on fences that can be included in logs. For example, multiple graphic, text vs depth, plot vs depth and bar chart vs depth columns can be included in each fence post. The following fence report plots water level symbols, a lithology column, and a samples column for each fence post:
