Error message opening System Properties in gINT
 Product(s):gINT Logs, gINT Professional, gINT Professional Plus
 Version(s):8.x
 Environment: N/A
 Area: N/A
 Subarea: N/A
 Original Author:Kathleen Holcomb, Bentley Technical Support Group
Error or Warning Message
Error on opening System Properties:
DialogControlsActivate.ActivateControl
Load List failed retreiving dialog number 32
Type mismatch
Explanation
This error will occur if a color is missing a color number.
How to Avoid
To fix this, go to Symbol Design -> Colors.  Look for any colors that are missing a color number.  Either delete the row or pick a color number for that color.
After saving you may get an error “Minimum allowed is 1”.  Click OK.  gINT will select a row where DXF Color Number is 0.  Enter a DXF color number between 1 and 255.
