| Product(s): | gINT Professional | ||
| Version(s): | N/A | ||
| Area: | Data Entry | ||
| Subarea: | |||
| Original Author: | Kathleen Holcomb, Bentley Technical Support Group | ||
When you import a DXF file to use as a site map in your gINT project, you need to make sure both the scale and the origin point of the map matches with borehole locations stored in the gINT project database. The method to correct the scale and origin point in gINT Software’s Drawing application follows.
This method requires that at least two borehole locations used in the gINT project database be marked on the original site map drawing. (If more are marked, choose the two located the greatest distance apart from each other as your “reference” boreholes.)
Once you realize the site map is not suitable “as is”, you can get rid of the imported .dxf drawing by turning off Site Map Support under Additional Modules.
Selected all the entities to Move.
Chose the center of the BR-1 borehole point (one of the minimum two boreholes with a position marked on the site map drawing) as the Handle Point by clicking on it.
This moved the map drawing so that the BR-1 location marked on it coincided with the position of the BR-1 borehole in the gINT data. If the scale factor had been the same, this would mean that both the site map and the gINT data had the same locations for all boreholes.
| BR-1 to AMW-1s | BR-1 to AMW-1b |
Scale Factor Calculation: 323.75 / 318.93 = scale factor of 1.015
We did this five times, because the distances measured can vary with the exact point where youclick.
The average scale factor came out to 1.014.
Since the site map was still not suitable, we turned off Site Map Support under Additional Modules to get rid of dxf_site_map.dxf file as the site map.
Once you click OK, you are asked to Select Entities to scale. We selected all the entities on the site map drawing, then clicked the OK button below the drawing area.
Next you are asked to enter the Base Point for scaling. We entered the X,Y coordinates for borehole BR-1 in the coordinate box at the bottom left. (These are now the same as the East, North coordinates from the gINT data.) We could also have clicked on the BR-1 borehole marker, but that would not be as accurate.
We saved the scaled map as dxf_site_map-scaled.dxf, and imported it as the new site map.
Scaling accuracy increases with the distance between the two “reference” markers.
Scaling accuracy also increases with the percentage of the map spanned by the distance between the reference markers.
In most cases, point selection by mouse will be less accurate than entering point coordinates in the box.
North and East coordinates will need to be calculated for the requisite two reference boreholes if you are using station and distance along a baseline or latitude, longitude as borehole locations.
