| Product(s): | gINT Logs, gINT Professional, gINT Professional Plus | ||
| Version(s): | |||
| Area: | Project Database | ||
| Subarea: | N\A | ||
| Original Author: | Kathleen Holcomb, Bentley Technical Support Group | ||
Changing the name of a field or table tab is generally not recommended. If you change the name you will probably have to change your report templates to match the new name. It is usually better to add a caption. The caption will then show in place of the name. This can be done in Input or in Data DesignProject Database. Changing the name of a field must be done in Data Design
Project Database.
Many table and field properties can only be modified in Data Design.
Go to the table/tab you wish to modify.
The properties dialog opens.
Enter a caption and click OK.
If you clone new projects from a data template remember to update your data template.
Right-click in the field and select Field Properties.
Go to FileOpen Project. Select a project to modify.
The field list for the Project tab/table opens.
From the big yellow drop-down list, select the table/tab you wish to modify.
Modify the table name and/or enter a caption and click OK.
If you change the table name you will see the Replace Field Names dialog.
After selecting which reports and library tables to scan, gINT will look for all instances of the old table name and replace it with the new name.
Select the field to modify and enter a caption.
For how to update a data template see What is a data template?
