| Product(s): | gINT Logs, gINT Professional, gINT Professional Plus | ||
| Version(s): | V8i and later | ||
| Area: | Installation | ||
| Subarea: | N/A | ||
| Original Author: | Kathleen Holcomb, Bentley Technical Support Group | ||
There is just one installer that installs all the gINT products: Logs, Professional and Professional Plus. During the installation process select the correct gINT product according to the license you have purchased.
On the Downloads page, to view the operating systems certified for gINT click the level of gINT you wish to install (as stated above: it is all the same installer and you will need to still select the level of gINT you wish to install). Select All Downloads. Under the Product Download title, select the name (for example gINT (Logs, Professional, Professional Plus, CLT) CONNECT Edition (CL) English) 32-bit) for the desired version.
The gINT Contaminated Land Tool is designed to manage and report on contaminants. It is used primarily in the UK but is equally applicable to other countries’ environmental standards/guidelines. It is now included in the gINT installer.
