| Product(s): | gINT Logs, gINT Professional, gINT Professional Plus | ||
| Version(s): | N\A | ||
| Area: | Licensing - Technical | ||
| Subarea: | N\A | ||
| Original Authors: | Kathleen Holcomb, Bentley Technical Support Group and Katie Aguilar, Product Specialist | ||
The product to be licensed is determined during the installation, which defaults to gINT Professional. There is no shortcut to start Logs vs. Professional vs. Professional Plus. To change from one product to another go to Help and select the desired product.
gINT will close. On reopening, it will launch as the desired product.
When gINT Logs is the selected product only the Logs option will show under the Output tab. You need to select either gINT Professional or gINT Professional Plus, depending on which type of license you purchased. Follow the steps above to select the correct product. On reopening gINT, you will see all the report options under Output:
