HoleBASE Data Entry Downloads
The following download types are available on request. Click on the header to go to the relevant page for that item.
Data Entry Module Profiles
A data entry template allows for quick and easy entering of information into your HoleBASE SI database. Each template is specifically designed to allow for a certain type of data to be inserted. For example, a Trial Pit template is set up to allow for any data that may be associated to a trial pit to be entered. Once imported, these templates will then be available within the Data Entry Module, both inside of HoleBASE and within the standalone tool.
