| Product(s): | Keynetix | ||
| Version(s): | 1.0 | ||
| Area: | Assist |
Date:3rd May 2019
Presenters: Phil Child with Oliver Carnaby and Steve Evason
In the next of our Small Steps Series Webinars, the consultancy team will be thinking about how you can use HoleBASE before you even step out on site and collect any data.
A lot of our clients don’t think about using our software until field teams have been mobilised to collect data onsite, where they will then upload to HoleBASE, or Keynetix.cloud and then use all of the features available to them. But there are a number of things you can use our software for before anyone has even left the office.
A number of features can be used to give you an idea of how the site will look and how the ground is made up, using just the information that is available to you through other methods from either your own team or through publicly available resources.
In this webinar, the team will go through how to bring in archive data, browse through web mapping services, show archive log outputs and generally enable you to better plan your site investigation through these techniques and more. This can then inform activity in the field, either as part of a walk over or as a set of instructions issued to a field team.
Please note that a login is required for access to the webinar archive. Registering is quick and easy, just click on the register button on the top right hand side of the screen.
