Webinar UK54 - An Engineers Guide to KeyLAB Laboratories
 Product(s):Keynetix
 Version(s):1.0
 Area:Assist
Date:5th July 2019
Presenters: Oliver Carnaby with Phil Child and Steve Evason
In the next of our Small Steps Series Webinars, the consultancy team will focus on “An Engineers Guide to KeyLAB Laboratories”.
Most site investigation projects require some form of laboratory testing, increasingly our KeyLAB laboratory management system is being used to fulfil this. Steve, Phil and Oliver will take you through how this data management system works so you can better understand where your data is coming from and the challenges the laboratory faces.
We will take you through how your data is imported and how it links together to give you your output data. We can demonstrate some of the challenges which are caused by mis-communications of schedules and their impact on the efficiency of the process.
For laboratory managers we can also show easy and simple ways to export statuses for schedules
https://vimeo.com/346815090
Want more free webinar recordings?
Click Here
Please note that a login is required for access to the webinar archive. Registering is quick and easy, just click on the register button on the top right hand side of the screen.
