How To Add Project Details to an Excel Extension Report
 Product(s):Keynetix
 Version(s):1.0
 Area:Assist
Explanation
When creating a excel extension report the project details aren't in any of the table. How would you added them into the sheet?
Process
Select the cell you wish to make part of the project details.
In this example, it’s the project ID. Once you have the cell selected you can go to Insert in the top ribbon. In the drop, down there is project details and within this list you will find all the relevant field to add.
The identifier is the project ID so I can click on it and it will add it to the sheet in the cell we have selected. The cell will flash green when its added.
