Instead of just a plot of some parameter (like CPT or other readings) on a log or fence with lots of blank space under the plot line, you can fill this area with graphics to show other information.
The area under plot lines can be filled with a graphic that always appears regardless of the project data. This is a “constant” fill. Alternatively, the user can be prompted at output time for the graphic to use. Finally, project, borehole, or depth-related information in the project can be used to determine the graphic.
