Create custom icons with ease
AskInga logo
Original Article Date: July 11, 2001
Ever spend hours trying to draw the little icons for your custom tools...only to be disappointed with the results? Read this article to find out how you can create professionally drawn icons in Microstation SE and J/V7!
Creating custom icons can be...well...a pain at the best of times. No matter how much care you take to draw them, they often end up looking like a 2 year old toddler drew them. MicroStation is delivered with a cool utility called IconEdit. Found in the program\microStation\mdlsys\asneeded folder, it allows you to import pre-drawn graphics, a cell or bit-map image to represent the icon. Follow these simple steps and you'll be creating cool icons in no time at all!
AskInga Article #77
