Original Tip Date: June 2002
Updated: May 2011
| AccuSnap Shortcuts | |
Need to suspend V8's AccuSnap for a moment? Or need AccuSnap when it is not active for the particular function - e.g. to snap a fence to particular points? If you have AccuDraw on, you can press HU to suspend. The graphic below was created in MicroStation V8i. communities.bentley.com/.../1016.hs.wmv
AskInga Tip #186
