*** ERROR: Class XXX Has Bad Segment Lengths" message
Q: What does the message *** ERROR: Class XXX Has Bad Segment Lengths" mean?
REV 7.00
A: Multiple class commands are used to describe the various segments for the class, and you must specify the length of the segments, except for one, for beam elements. The length of the segment not specified is computed from the distance between the nodes, minus the specified segment lengths. The error message can indicate a few things:
Title:
Tag:
