Q: Why do I sometimes get the message "*** INFORMATION: Too Many Selected Maximum is 8 - Excess is Ignored" when I am reporting locations of points of interest?
REV 7.04
A: The 8 point limitation stems from the amount of real estate we have available on a page for the report. If you need more, loop over the commands providing the information you want, changing the interest points in each step.
