"*** WARNING: EQUILIBRIUM NOT FOUND WITHIN TOLERANCE" message
Q: Why do I get the message "*** WARNING: EQUILIBRIUM NOT FOUND WITHIN TOLERANCE"?
REV 7.00
A: This means the program could not find equilibrium within the given tolerance using the given number of iterations. Normally, the user needs to determine the cause for this: either the program is chattering about a solution, or more iterations are required to find a solution. Typical solutions for this include specifying a better initial condition, or changing the default -OMEGA value.
