Produce a "movie"
Q: How can I produce a "movie"?
REV 7.01
A: First you need a time domain or static process to animate. Then make a picture. Find the view you like and press the "play" button to preview the movie. If you like what you see, either use the "Pictures"/"Movie" buttons or the command &PICTURE -MOVIE to produce the movie.
