Q: If I specify that a tube is -FLOODED YES and the tube accelerates, is the inertia of the entrapped fluid included or omitted?
REV 7.05
A: MOSES assumes that the tube is open at the ends. Thus, the inertia included for acceleration perpendicular the centerline and excluded for acceleration parallel the centerline.
