Q: What formula is used in MOSES for determining radius of gyration?
REV 7.00
A: The recipies MOSES uses are those in any undergraduate dynamics book. Local plate inertia is ignored, and beams are assumed to be slender; i.e. the size perpendicular to the centerline is small in comparison to the length. Other than this, the computation is exact.
