Basis for the Suggested Added Mass and Damping for Launch Barges
Q: What is the basis for the suggested added mass and damping for launch barges?
REV 7.04
A: Originally these numbers were based on the high frequency results in a frequency domain analysis for nominal launch barge in a nominal launch position. These values have been used for the launch analyses since 1980s, and some slight changes have been made based on feedback from the actual launches.
