EARLIER
Q: What coordinate system is used for the reports in the Structural Post Processing menu?
REV 7.05
A: The reports in the Structural Post Processing menu are reported in the beam coordinate system. You can ask MOSES to tell you what this system is in the &summary menu with the BEAM command.
