EARLIER
Q: Are the "Stress Cycles" reported with "counting" peak to trough values or amplitudes?
REV 7.06
A: These results are the exception to the rule that nothing in MOSES is peak to trough. Stress Cycles are peak to trough to be consistent with the definition given in almost all sources.
