SACS Seastate Solutions
This contains SACS wikis related to the SACS Seastate program.
  1. Base shear comparison
  2. Does SACS handle breaking waves?
  3. ERROR - NO STREAM FUNCTION SOLUTION IS POSSIBLE
  4. Hydrodynamic coefficient input for the lines: CDM, MGROV & GRPOV
  5. Hydrostatic collapse using LDOPT line and HYDRO line
  6. Moving Load Application
  7. Negative Space Load
  8. Plate Load Generation during Launching of Jacket
  9. Stream Function Wave Based on Atkins
  10. Using Corrosion in Seastate analysis
  11. Wave + Current Combination
  12. Wave loads comparison between analysis
  13. Wave Output Print Option
  14. Wind Card
  15. Wind Load calculation Using API
  16. WAVE definition - YLOC card
  17. Wave Forces on Large Tubular Columns - MacCamy & Fuchs
  18. Wave Drift Current
  19. Dummy Member and joints
  20. Wake Encounter
  21. Density Calculation for buoyancy
  22. Buoyancy calculation of cone
  23. Irregular wave equation
  24. Stretching in user defined sea surface
  25. Diffraction - McCamy-Fuchs correction
  26. Hydrodynamic coefficient with height
  27. Single and Double Skin Grouts
  28. NL Current Stretching
  29. Minimum Inline Current
  30. Drag coefficients for open sections above water level
  31. User defined wave- Velocity & acceleration calculation
  32. COG for Z directions not showing in "Seastate Load Case Center Report"
  33. Corrosion Zones Overlap
  34. COUPLE force in Load Case Centre Report
  35. Dynmas card is getting deleted
  36. Non-Structural Elements in SACS
  37. Buoyancy in Seastate vs Floation
  38. Including Marine Growth Weight in Dynpac Analysis
  39. Why CoG and CoL Do Not Match in Seastate Load Case Reports
  40. Hydrodinamic coefficients Using Wake encounter option
