SACS Fatigue Solutions
This contains SACS wikis related to the SACS Fatigue program.
1. Selection of "free corrosion" DNV curves
2. SCF Method for Inline connection (DNV Options)
3. SCF Method for Inline connection using ISO
4. *** ERROR - LOAD CASE X HAS PERIODS NOT IN DESCENDING ORDER
5. Fatigue Time Period vs Fraction of Design Life
6. Spectral fatigue Tow and Hull deflection
7. Speed up Fatigue Analysis
8. Weibull Distribution - K & A Parameters
9. Combining Fatigue Extraction Results
10. Combining Multiple Fatigue Analysis - SACS Damage files (ftgdmo.)
11. Defining Ring with CONRST line
12. Eccentricity or fabrication misalignment and Warning Using DNV-RP-C203 "DN5"
13. Fatigue Below Mudline
14. Grout in Pile Fatigue
15. Inspection points for SCF calculation
16. Joint Flexibility and Behavior in Transfer Functions
17. Relationship between "Stress-DA" on the response spectrum plots vs. the RMS stress in the Fatigue Stress and Damage report
18. Scatter Diagram and Frequency of occurrences in fatigue
19. SCF for a specific Joint connection?
20. Transfer function in wave response vs Transfer function in Fatigue
21. Use of the command MEMSCF and GRPSCF
22. Fatigue results Error Load case number match
23. Yoke Plate to jacket SCF Calculations
24. Influence Function in SCF calc
25. Transfer Function for Harris Spectrum
26. FTLOAD Data
27. Print connection transfer functions and response spectrum output
28. SCF Calculation using DN2 and DN3 option in SACS
29. Multiple SN Curve input in SACS Fatigue
30. SCF option for Weld Root in SACS Fatigue
31. How to set up a non-tubular SCF extraction using Joint Mesher tool?
32. How to remove "Transient Duration" out from fatigue calculation
33. Fatigue Load Conditions Settings
