| Product(s): | SACS Offshore Structure Enterprise | ||
| Version(s): | 05.06.02.03 | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
| Original Author: | Jeremy Hoesly, Bentley Technical Support Group | ||
When running an analysis, multiple errors of the following form appear:
Writing Output File: Access to \sxxx. was denied.
A known issue with SACS 5.6.2 causes this error. SACS 5.7 addresses it. The following workaround can be used in SACS 5.6.2.
