While Bentleys Systems provides a text editor with the installation of SACS, there are other text editors that you may prefer. In this guide, we will walk through the installation of Notepad++ and updating the default text editor in the SACS settings to Notepad++.
Notepad++ is a free, open source text editor under the GPL License.
Now when opening listing files through the SACS Executive or generating reports from Precede, Notepad++ will open instead of the included SACS text editor.
Also, clicking on warning or error messages in the error log will cause the listing file to open at the error line in Notepad++.
This can be done with other text editors, but you might have to consult the documentation to find the correct Goto command syntax.
