WaterSight - What is New (October 2026)
What's New (October 2026)
ArcGIS Integration Improvements
WaterSight supports direct connection to ArcGIS online and ArcGIS Enterprise (on premise).  More information is available here.
In the latest release the following improvements have been made:
1. Persisting and storing ArcGIS layers
Now, whenever new ArcGIS layers are added through the map layers widget, those layers are stored when navigating between different pages in WaterSight or between different sessions. Those are also available to all users.
2. Displaying layer properties
Whenever the connection to ArcGIS layers is done and layers are available on the map layers widget, automatically on the top left side will be available the "Map Layers info Tool". Click on that button and then select the layer directly from the map to check its properties.
Water Audit - Display message if SIV is not calculated
The System Input Volume component displayed on the Water Balance diagram now shows a tooltip with more information whenever the data can not be calculated, as shown in figure below.
More information about why system input volume might not be calculated is explained here - Water Balance Diagram.
Water Audit - Update Zone Recompute message
The message that is displayed in the Zones administration page (when changes to zones are made which affect the monthly water balance calculations) was updated to an informative message with more information.
Whenever zone changes are done, the past monthly water balances are not updated accordingly and only future water balances will consider the new definitions. In case the user wants to override or update the historical monthly water balances according with the new settings it is required to click on the zone recompute button, which can be accessible through the (...) button located on top of the table. More information about recomputing zones can be found here - Zones Administration.
Billings Upload - Increase limit of records
The maximum number of billing records that can be uploaded (in Admin >> Customers >> Billings) via one single CSV file was expanded from 1 million to 5 million registers.
Add Model Forecast results to Network Monitoring Graphs
When toggling on model results on the sensor graphs, now it is also displayed the forecasted model results (blue line). More information here - Accessing Model Results.
What is New (August 2026)
OpenFlows Product Release Notes (New Features and Enhancements)
