ASCE 7-22 Seismic USGS Lookup tool broken
Product: RAM Structural System
First Affected Version: 2025 (25.00.00)
Fixed in Version: 26.00.00
Area: Frame - Analysis
Issue #: 2081751
Problem Description
This applies to ASCE 7-22 Seismic or Dynamic load cases in RAM Frame after June 2026. Using Method 1, clicking the "Read From USGS Seismic Design Geodatabase" button clears previously populated seismic parameters (Ss, S1, SMS, SM1, SDS, SD1), resetting them to zero instead of retrieving data. The problem occurred due to a change in the location of the USGS server for retrieving this information.
Work Around
Models that previously looked up values will still use those values. For new load cases or changes in location, the only option is to switch to Method 2.
Fixed for version 26.00.00 (July 2026).
