WaterSight - Updating signal tags in the WaterGEMS model
To enable a real-time model in WaterSight, one of the prerequisite steps before uploading a WaterGEMS model into WaterSight is to create or update the SCADA signals in the WaterGEMS model. It is a requirement that each signal tag is consistent with the corresponding sensor tag configured in WaterSight (Admin > Sensors > Sensor Tag) and matches the tags defined in the underlying database or data source.
The most efficient method for adding new SCADA signals or updating existing signal tags in the WaterGEMS model is to use the ModelBuilder tool. This approach simplifies the process of aligning SCADA signal tags with those configured in WaterSight. The video below demonstrates both scenarios.
For more information on how to prepare a WaterGEMS model for real time simulation in WaterSight, take a look at this article - WaterGEMS Setup Guide.
See also
