Fatigue Analysis as per ASME Section VIII Division 1 in AutoPIPE Vessel
Summary
ASME Section VIII Division 1 does not include explicit fatigue analysis rules. Therefore, direct fatigue analysis is not available in AutoPIPE Vessel when Div. 1 is selected.
Recommended Workaround
To evaluate fatigue for a Division 1 vessel, use ASME Section VIII Division 2 for fatigue checking.
Steps:
    1. Copy the existing ASME VIII Div. 1 model.
    2. Change the design code to ASME Section VIII Division 2.
    3. Define pressure cycles and number of cycles.
    4. Run fatigue analysis.
    5. Check that the fatigue usage factor ≤ 1.0.
Note:
Bentley AutoPIPE Vessel
Support Solutions and FAQ's
Error Messages
Warning Messages
Calculations
